Caveman_Charlie's avatar
Caveman_Charlie
Explorer II
Mar 30, 2022
Battery operated fan quesiton ?
In my Travel Trailer I'm set up for camping without electricity, I have 2 - 6 volt golf cart batteries they run everything in the RV.
I also have 2 fans that run on the USB port inside the camper that is connected to the batteries. These fans draw a total of 5 watt. This keeps me, the girlfriend, and the dog comfortable enough after dark when the temps in MN drop down anyway.
I bought a cheap pop up camper this winter and I'm planning on using it for a couple of trips this summer. I will be camping in it for 4-6 days at a time. This will just be me camping all by myslef. The pop up has no battery of any kind and I will be going camping at places without electricity. This old pop up has no systems anyway. It's just a tent on wheels. I don't want to spend a lot of money on the old thing.
I would like to run a fan at night for ventilation and white noise. One of the USB fans at 2.5 watt would be good enough but, 2 for a total of 5 watt would be better.
You can purchase portable power stations but, they cost probably close to 200 dollars, or more, for a decent one. That's a lot of money for something I'm only going to use twice to power a fan.
I've looked at battery powered fans (there is a dizzying amount of them) that can be as cheap as 35 bucks but, they never seem to run for more then about 5-6 hours and then take several hours, up to 8, plugged into the pickup the next day to recharge. Some of them require 115 volts to recharge. (My pickup does have a 115 volt outlet but, it's only powered when the engine is running. So that is not very convenient )
So, What I'm looking for a fan that moves some air, makes some noise, runs for 8 or more hours and can be charged back up in 2-4 hours. Is there such a thing ???
If not what can I use to run the USB fans for a affordable amount of money ? Could I take a car battery along and run the fan for several nights then recharge it in a few hours ??? It almost seems to be the cheapest way but, it would require me to drag along a old car battery and a car battery charger. That is not very convenient either.
Does anyone here have any experience with battery powered fans ? If not is there another forum you can recommend ?
I just can't decide which route to take.
Thank you and have a nice Day.
  • You could use 12V fans powered from the tow vehicle battery, connect to the battery or cig plug.
