mrekim
May 04, 2015Explorer
Bearing Question
I asked this in the travel trailer forum in a thread about seals and decided that asking here might be more appropriate: I repacked the bearings on one side of my trailer that had the factory lube ...
Damage Condition
Wear occurs due to repeated sliding between the
two surfaces. Fretting occurs at fitting surface and
also at contact area between raceway ring and
rolling elements. Fretting corrosion is another term
used to describe the reddish brown or black worn
particles.
Possible Cause
Poor lubrication
Vibration with a small amplitude
Insufficient interference
Countermeasure
Use a proper lubricant
Apply a preload
Check the interference fit
Apply a film of lubricant to the fitting surface
