mrekim
May 04, 2015Explorer
Bearing Question
I asked this in the travel trailer forum in a thread about seals and decided that asking here might be more appropriate: I repacked the bearings on one side of my trailer that had the factory lube ...
mosseater wrote:fj12ryder wrote:
Any hole or opening that is going to go through a seal should have the edges chamfered. If you can't do that put a small piece of tape over the hole to protect the seal, then remove it when it's through.
Excellent point. I chamfer the edge of the grease hole with a fine stone and electrical tape around it is a good idea. Let a long tail of tape and pull it free after the seal lip has passed beyond the hole.
