DCamp84 wrote:
laknox wrote:
One thing nobody has mentioned, and I can't find in the specs, if this rig has a black tank flush. If so, then it makes more sense to leave the grey tank open, if you want to. For me, I hook up my hose, turn the flush on for about a minute (if not real full), then dump the black, while leaving the flush running. When it's done, I close the valve and leave the flush running for about 5 minutes, maybe longer (have 45 gal capacity), then dump again, then repeat. Use the grey water afterwards to rinse the hose. If you =don't= have a built-in black tank flush, then it might be smart to get, or make, a wand that you use to do the same thing, but from the toilet. Just need to be d@mn careful when you do this, though. :o
Lyle
I have a clear elbow with a flush hose hook up built in to it. Do you think thats good enough or is the wand a must?
The wand is handy to have (hell, you can =make= one from PVC, some fittings, nozzles and a drill) for when you get the dreaded poop pile (there's got to be a Monty Python routine there, somewhere) and need to bust it up. I've never had, or used, one of the clear elbows, but a lot of people swear by them. The elbows don't really have the power of a wand or installed flush system, only give you the ability to add lots of water to rinse the tank. A wand gives you the "power wash" you might need to break up hard stuff, especially if your tank ever dries out.
Lyle
