BarneyS
Jul 27, 2020Nomad
trail-explorer wrote:mleekamp wrote:
My initial reaction, after being confident you've installed it correctly (pics seem to show that), is you might have tightened the handle/screw TOO TIGHT.
DITTO
It sometimes pays to read the whole thread. The OP discovered the reason for the bent sway control. It was the v shaped rod welded to the side of the trailer A frame contacting the sway control during a left turn.
As far as tightening the sway control handle, I also posted the correct procedure for using that which was confirmed by the posting later on by a member of the written instructions. Here is what I said earlier in the thread regarding this.
"As far as tightening down the handle all the way, the factory sets the "clamping power" for the average trailer. The purpose in tightening the large upper handle all the way is so you can be consistent in the amount of tension on the bar once you find the measurement that works right for you. The adjustment for this is the small bolt below the handle, which should be turned in 1/4 turn adjustments, as a little goes a long way."
Notice that the handle is simply supposed to be an "on/off" device and not a way to adjust the tension on the sway bar.
Barney
Looking for advice before your next adventure? Look no further.25,214 PostsLatest Activity: Feb 11, 2018
