darleyhavidson
Mar 06, 2018Explorer
westend wrote:
The best solution to this repair is to use Eternabond Webseal Tape. I will conform to any radius surface. The Webseal tape needs to be covered with a sealer or paint. Eternabond Roofseal tape can also be used but the top vinyl layer will tend to interfere with sharp radii. I have both on my trailer roof, the Webseal is installed over the edge trim's vinyl screw cover.
If I use the Webseal tape, will the sealer/paint, that needs to be applied, be able to withstand being applied to a vertical surface without sagging/dripping? Would you use Webseal into the gutter area or stop short?
Looking for advice before your next adventure? Look no further.25,207 PostsLatest Activity: Aug 26, 2026
