darleyhavidson
Mar 06, 2018Explorer
spoon059 wrote:darleyhavidson wrote:
With my gutter, I have this rubber/vinyl rail above the gutter which I think helps attach the roof membrane to the camper. In the attached picture it is the piece with the blue arrow pointing at it. Do you see any issue with the Eternabond being placed over it?
The rubber/vinyl trim is not solid and has space behind it, kind of like an air cushion. So, rolling the Eternabond over it to getting it to attach might be a little problematic.
Yup, looks similar to mine. I kept my tape just barely touching the top edge of that trim. That trim just covers the screws that hold the gutter to the wall, FYI.
Ok, thanks for the info. And did you follow up the with Dicor sealant at the seam between the Eternabond and the trim edge? Did you use 2" wide or 4" inch wide Eternabond. The more videos I watch, plus the info on this forum, is giving me more confidence to just do the entire roof perimeter (which should give me piece of mind over the next several years of camper ownership).
Looking for advice before your next adventure? Look no further.25,207 PostsLatest Activity: Aug 26, 2026
