rjsurfer
Sep 25, 2016Explorer
samandtheduck wrote:
I've had a Vornado since 2005 and it has been the best heater for keeping our 33' heated. I have owned a few cheaper heaters we have used as a second heater when the weather got close to freezing but none of them worked very well. I finally bought a second Vornado and threw all the cheap ones away. The Vornados circulate the air even when the heat is off and if you set the temp. at 70 degrees it stays within a degree of 70 degrees.
By far my best investment in keeping my camper warm.
Vornado moves a lot of air, which is just as important as making heat.
Let's face it ALL 1,500 watt heaters produce the same amount of heat, so moving the air and keeping it at an exact temperature and doing so quietly are the only differences. Vornado excellent in all three.
Ron W
Looking for advice before your next adventure? Look no further.25,199 PostsLatest Activity: Jun 10, 2026
