travelnutz
Sep 26, 2016Explorer II
Our 5,200 BTU quartz element LED electric movable fireplace we have in our 5th wheel also has total remote control plus full controls on the front of the unit. Push the remote buttons for on or off, fan only, 3 settings for flame brightness, 3 speeds for flame speed, 3 fan speeds, high and low for heat wattage output, and has digital remote thermostat setting levels by each degree desired. Has a tip over safety switch too. Looks like a piece of fine quality wood furniture and available in several wood grains/stains or even white if preferred, not an add on after thought heater. One negative is that it's a little too large for most slide-in truck campers but I have seen one that had been built in by the owner and it looked like it was OEM manufactured. Very reasonably priced too. What more could you possibly want??? The total pleasant experience in heating and ambiance when inside the RV!
ONE visual appealing functional fireplace unit that does it all and can be moved around in the RV to where wanted anytime and also simply take from RV to RV unit as desired or even use it at home also. Only needs 6" clearance from combustibles on either side or the rear, zero under or on top, and 12" on the front per the printed instructions. Mainly because the heat output is channeled thru a widely dispersed grill and not a small concentrated area of very hot temps.
Did I say that we absolutely love our fireplace in our 5th wheel?
Looking for advice before your next adventure? Look no further.25,199 PostsLatest Activity: Jun 10, 2026
