rjsurfer
Sep 26, 2016Explorer
pasusan wrote:rjsurfer wrote:Weez agrees - this is what we have - it is the type that keeps the fan going even when no heat is needed so there is no on and off noise to wake us up at night. The cabinet stays cool to the touch which was important for us as we have 2 cats. And it has the tip over protection - what more could you ask for?samandtheduck wrote:
I've had a Vornado since 2005 and it has been the best heater for keeping our 33' heated. I have owned a few cheaper heaters we have used as a second heater when the weather got close to freezing but none of them worked very well. I finally bought a second Vornado and threw all the cheap ones away. The Vornados circulate the air even when the heat is off and if you set the temp. at 70 degrees it stays within a degree of 70 degrees.
By far my best investment in keeping my camper warm.
Vornado moves a lot of air, which is just as important as making heat.
Let's face it ALL 1,500 watt heaters produce the same amount of heat, so moving the air and keeping it at an exact temperature and doing so quietly are the only differences. Vornado excellent in all three.
Ron W
Yes, the fan stays on and is cool to the touch, I don't know about the tip over protection to be honest. Never tried it out, look at their model breakdown on the website, probably will give you all the info.
Ron W
Looking for advice before your next adventure? Look no further.25,199 PostsLatest Activity: Jun 10, 2026
