lenr
Apr 19, 2015Explorer III
If the OP’s Reese WD bars have the crook in the end (not straight) then the next step up would be to add the Reese Straight Line (other name-> Twin Cam) to the existing hitch. The only way to change tongue weight is to shift cargo in the trailer from the rear to the front. Changing the links on the WD only changes the distribution of the tongue weight from the rear to the front of the tow vehicle. Too little WD bar “could” cause a bit of over-steer.
Looking for advice before your next adventure? Look no further.25,214 PostsLatest Activity: Feb 11, 2018
