jerem0621
Apr 19, 2015Explorer II
Hi OP,
Just for the record on the air ride for a 2015 Tahoe here is the owners manual...
Sway vs Natural Movement
We need you to clarify something... Are you getting real sway or is the trailer moving around some when you get passed?
there is a natural push-pull motion that you will get from passing vehicles...no matter what...the idea is to make the push pull motion act against the TV and the TT as one unit... The unnerving part about towing is when you can feel this suck pull act on the trailer, then as the pressure wave reaches the TV you can feel the trailer moving back into the lane as the TV is pushed in another...
Ideally, the pressure waves from passing vehicles and the wind blowing on the side of the vehicle push the entire rig as one...no independent Movement between the TV and the TT... One solid push is much easier to deal with than lots of little movements.
If you are Swaying.. as in this video then we have some serious issues to address. Your trailer should not be swaying.
We need to deal with the "other factors" that impact these little movements.
Wheelbase vs rear Overhang
....the Tahoe/Yukon does have a shorter wheelbase than the Suburban but the rear overhang on the shorter Tahoe/Yukons is much less. Rear overhang is the distance from the rear bumper to the axles.... The less rear overhang the better. I don't have the figures in front of me know but the long rear overhang on the suburban offsets some of the benefits of the longer wheelbase, and vice-versa for Tahoe/Yukon shorter wheelbase with short overhang.
In the end the towing prowess of the 2015 LWB Suburbans/Yukon XL's vs the shorter Tahoe/Yukons are basically the same.
Tires
One of the reasons that people see an improvement when they move from a half ton to a 3/4 ton is due to tires....
No, I don't recommend you change your tires to LT tires that are found on 3/4 ton trucks... not yet.. lets work with what you have for now.
Check out your payload sticker on your door.. Here is an example from one from a 2015 Suburban that I had as a rental...
Notice that the tire pressure is listed at 35 PSI? Huge chance that this is your problem unless you are already doing what I am about to recommend.
Here is the tires off of the same Suburban....
you may have to zoom in to see it.. but these tires are rated to 51 PSI max... Guess what PSI I would be towing a TT at? You got it.. 51 PSI. I highly recommend airing your tires up to MAX PSI before every tow. It should improve your towing experience... possibly significantly...
Airing up the tires to 51 PSI (or whatever the max PSI is on your sidewalls) will stiffen up the tires and help keep the squishy out of the tires.
Weight Distribution
I have not adjusted a hitch with the air ride suspension.. what I am hearing from the screenshot above and other users is to let the air ride air up, preloading the shocks... then turn off the air ride and hitch up, adjust the wd hitch.. then turn on the air ride again.... The same owners manual says that you need to try and get the front fenders back to factory height. basically, no rise or drop on your front fenders once the WD hitch is adjusted.
Sway Control
You have a single sway bar... one of these type devices..
You need two... one on either side of the tongue.. I am sorry for this terrible picture, but its what I have readily accessible
To run two bars with your current hitch you will need to weld on a sway bar mount to the hitch head because Reese in their infinite wisdom thought that adding only one mount to your Reese head was totally awesome. (Truth is they want to "upgrade you to Dual Cam Sway Control"
A new tab that a welder can weld to your hitch head will be provided with the new Sway bar if you choose to go this route.
or you can add Dual Cam Sway Control to your current hitch. its finicky.. and I don't like it personally. Many run it with no problems. I personally prefer the old fashioned friction bars.
Hensley hitches, ProPride, and the PullRite hitches are all options that eliminate sway period.. But these are HEAVY beasts of a hitch (150-200 ish lbs) and can put Half Ton towers over their receiver capacity if they are running close to max already. GREAT HITCHES though.
Vehicle Loading
I would pay attention to your vehicle loading... I would try to keep only light stuff in the back.. load the trailer with the stuff as much as you can.
Try to keep it so that the TV is doing two things from a payload standpoint while towing...
1) Carrying People
2) Carrying the Tongue Weight
Heavy stuff needs to be in the trailer.
Hope this helps some...
Thanks!
Jeremiah
Tires
Weight Distribution
Sway Control
Vehicle Loading
1) Carrying People
Thanks!
Jeremiah
Looking for advice before your next adventure? Look no further.25,214 PostsLatest Activity: Feb 11, 2018
