paddykernahan
Aug 23, 2019Explorer
ajriding wrote:
I wanted to have one but then did the research.
It will work if you are hooked up to a water source such that when showering you can let the water run the whole time, and are great if you plan to take long showers and waste water…
Bad if you want to conserve water if not hooked up. As soon as you stop the flow the water in the tankless gets hotter, then when you resume you get that hotter water, and when you let it run longer the temp goes back down. No steady temp is possible with the military shower method. Unfortunately the hot water heater is the only way for this. I wish I had a two gallon water heater as I take 1 gallon showers…
In the summer I have learned to just take cold showers. This helps a lot to save water since I boondock it is important. After two showers you get used to cold water and it is not different than washing your hands in cold water.
Agree.
We dry camp mostly so water conservation is needed.
I plumbed a line with a "Y" and valves from the hot water low point drain back to the fresh water tank drain.
When diverter valve is on, hot water constantly runs through the system and dumps back into the fresh water tank. Seems to stabilize the temperature when shutting off and turning on the shower hot water.
When done showering, turn off the water pump.
Turning the valve in the "Y" diverter puts the system back into original configuration so pump can be turned back on for normal operation.
This also save the extra water wasted waiting for the hot water to get to the bathroom. Still needs to purge cold water from the shower head hose so less ware wasted.
Looking for advice before your next adventure? Look no further.25,204 PostsLatest Activity: Aug 13, 2026
