T18skyguy
Aug 24, 2019Explorer
If your going to get a tankless get the Truma. If you do a lot of boondocking or desert camping it's pointless to have it. I have a Girard, it works well, but with any tankless you operate differently than your home shower.First you need acceptable water pressure and flow. Buy a good adjustable water pressure valve and keep the pressure at 40-60 psi which works good for me. Set the temperature on the thermostat to 100 or so, then turn the hot water on full. You don't need the cold water cause the shower temp is set at the thermostat. Mine works fine with this method. A good adjustable quality water pressure valve is a Renator. You can find it on amazon. My Girard will run for 20 minutes, then it cycles off to protect the electronics from too much heat.
Looking for advice before your next adventure? Look no further.25,204 PostsLatest Activity: Aug 13, 2026
