tomseeley's avatar
tomseeley
Best way to check trlr brakes AND integr brake controller
I've got a 2013 GMC 2500HD diesel. I'm pulling a Northwood Nash 26X trailer (not a fiver). Everything works fine, as near as I can tell, but I have one question re trailer brakes.
I took the rig out for the first time this season (since last summer) and I noticed that it did not feel exactly like it used to last year when I applied the truck brakes. I did not have trouble stopping and I did not cancel the trip, but I did drop the trailer off at my local RV center for routine inspection of the brakes, etc.
While driving down the road, with the gain on the GMC integrated brake controller set at 6 where I always set it, I pinched the buttons on the dashboard, at low speed (15-20 mph). It did not feel to me that the trailer brakes grabbed as tightly as I thought they had last year. So that's why I wanted my shop to check the brakes.
That's the background. Now here's my question:
I've had trouble communicating before, with the chap at the RV center. I had trouble this time too. When I told him my concern was that my integrated GMC brake controller did not seem to make the trailer brakes work this year like I thought they had last year, his answer was something like: "integrated brake controllers don't work like third party add on brake controllers do". That seemed to be his way of saying I didn't have a problem at all with my trailer brakes. I kept repeating that my concern was not how my existing OEM integrated brake controller worked compared with some other add-on controller I've never had; my concern was that my existing OEM integrated brake controller does not seem to be working this year the way the same controller has worked in the past!
I never did get my point across to him the way I wanted to! He said, with some sarcasm in his voice, "ok, we'll check the trailer brakes..." but it was obvious he was finishing the sentence to himself by saying "but there's probably nothing wrong with them. It's just your imagination that your integrated brake controller isn't doing what you think it should".
So does he have a point or do I have a possible trailer brake problem?
What IS the best way to check trailer brakes and an integrated brake controller?
  • The IBCs are smoother operating, using the pedal. When operated manually, they are similar to other types.
    If you used the same IBC last year, and it is not working as well this year, then yes, the brakes likely need to be adjusted.
    My IBC works great, it is set at 5, and will just lock the wheels, when quickly grabbing the manual control at 20 mph.
    Jerry
  • as they ware they don't feel the same. Adjust them or turn the brake controller up a little and see if that helps. Nothing stays the same forever.
  • Drive down a street at low speed and apply trailer brakes using brake controller manual lever
    Should feel trailer 'tug' on tow vehicle
    Do same when at full stop......apply brake manual lever and then slowly drive away. Should feel that tug/resistance from trailer
    And being that trailer brakes (majority) are NOT self adjusting.....one should manually adjust trailer brakes beginning of each year so that they are properly set ready to grab when needed.
