mikeinaz wrote:
Is there a 'best' way to engage or hook up the WDH chains or does it not make a difference? I have an EAZ lift and have always lowered the tongue onto the ball just slightly to create some pressure on the tv and have then slipped the 3rd link on the chain onto the tongue and used the bar to pull the mechanism tight on each side. Then I finish dropping all of the pressure down on the tv. Is this ok or would it be best to put all the pressure on the tv first and then engage the bars? Or does it just not matter? Thanks!
That's how I did it with my old EAZ Lift hitch on my old trailer. Put a little pressure on the ball then lifted the snap up brackets. I basically do the same thing with my new Equalizer. In fact, that's what Equalizer recommends. I don't need the pull up bar.
