the_happiestcamper wrote:
Ron3rd wrote:
That's how I did it with my old EAZ Lift hitch on my old trailer. Put a little pressure on the ball then lifted the snap up brackets. I basically do the same thing with my new Equalizer. In fact, that's what Equalizer recommends. I don't need the pull up bar.
Equalizer's web site says different:
1. Place the Equal-i-zer hitch head and shank into your tow vehicle receiver.
2. Back up to the trailer, lower the trailer onto the hitch ball, and lock the coupler.
3. Insert the spring arms into the hitch, and pin them in place.
4. Use the tongue jack to raise the trailer and tow vehicle until the spring arms are high enough to swing easily into place over the L-brackets.
5. Occasionally you may need to use the included snap-up lever to lift the arms the last inch or so onto the brackets.
6. Pin the arms into place, and retract the tongue jack completely to lower the weight onto the hitch again.
7. Connect everything else (breakaway cable, safety chains, and electrical connections), and you're ready to go.
8. Have fun.
Correct, I did not make myself clear, the EQ procedure you posted is exactly how I hitch up my Equalizer hitch. After dropping the coupler on the ball, lowering the coupler and locking the coupler, I raise the tongue back up with my Atwood electric tongue jack and swing the bars over the L Brackets. On my old EAZ lift hitch, I would put the coupler on the ball and apply just a little weight then snap up the chains, then lower the coupler all the way.
