darleyhavidson
Mar 10, 2018Explorer
Gdetrailer wrote:
Are you sure it is bacteria?
Water with high iron content can also cause rotten egg (sulfur) smell from water heaters which have a lined steel tank (Suburban brand) and a second anode rod.
As the anode rod wears out, the rotten egg or sulfur smell will get bad..
Not sure if aluminum water heat tanks (Attwood) have the same problem.
For Suburban tanks the fix is replacing the anode rod with a new on, do not cut off the rod and put the plug back in, doing so will drastically shorten the life of the tank.
Ideally, the way to fix high iron content water is through a iron removal system, in a pinch a decent water softener can be used although may not be totally effective.
Rather than guessing, I would recommend getting the water fully tested by a professional water testing service. Make sure the test checks for bacteria along with iron/mineral content. This way you KNOW FOR SURE what you are dealing with.
If bacteria is present in the water, then the campground should be held responsible for fixing the problem.. Either by treatment or new well and sanitizing their water system.
If they refuse to do so, I suggest you consider finding a different campground that values your well being..
Have had several mobile home courts around my area shut down due to bad water..
That is a fair statement. It could be high iron content. My camping neighbors are experiencing the same smell. We experienced the smell at the exact same time, so that is why we assumed it was a well water issue versus a singular camper issue. I had a Suburban water heater last season (with anode) with my old camper. My new to me camper has a Atwood brand aluminum water heater.
Basically, I am trying to get ahead of the problem before the start of this camping season. I will see if I can find the water health report for the county the campground is located.
Thanks for the feedback.
Looking for advice before your next adventure? Look no further.25,199 PostsLatest Activity: Jun 10, 2026
