mkirsch
Apr 18, 2016Nomad II
MMayleben wrote:
Ok good deal, thank you everyone for the information!
So dial back about .5 (that's the increments on my factory controller) from when the wheels lock up? I just wanted to make sure I wouldn't burn my trailer brakes up quickly if I used too much brake. This helps a lot.
You will never wear the trailer brakes out, so use 'em. Set them as aggressively as you can tolerate.
The technique described here is definitely a good one, but you will eventually develop a feel for when the trailer is braking to your satisfaction.
Looking for advice before your next adventure? Look no further.25,187 PostsLatest Activity: Mar 17, 2026
