GlampinLife
Apr 18, 2016Explorer
mkirsch wrote:MMayleben wrote:
Ok good deal, thank you everyone for the information!
So dial back about .5 (that's the increments on my factory controller) from when the wheels lock up? I just wanted to make sure I wouldn't burn my trailer brakes up quickly if I used too much brake. This helps a lot.
You will never wear the trailer brakes out, so use 'em. Set them as aggressively as you can tolerate.
The technique described here is definitely a good one, but you will eventually develop a feel for when the trailer is braking to your satisfaction.
Ok that's good to know. Being new to these types of trailers, I wasn't sure how much use you can get out of the brake pads. I'd rather use too much, than not enough and hit something.
Looking for advice before your next adventure? Look no further.25,187 PostsLatest Activity: Mar 17, 2026
