Apr 24, 2016Explorer II
Goostoff wrote:
A quick chirp on your tires is not going to leave flat spots on your tires.
My suggestion would be to disconnect the factory brake controller and get yourself a P2 or P3 and not worry about adjusting them ever again. I old P2 and now my new P3 have both been set the same way. I crank them to the max setting and forget it. The controller only applies as much brake force as is needed so I never even feel the trailer pushing me down steep hills or trying to send me through the windshield on flat ground. If I am just stopping on flat ground the display will usually be 1.8 to 2.5 or so and if I am rolling down a steep hill the display will usually read 5.5 to 7.2 depending on what is at the bottom of the hill. After I gave my nephew a demonstration of this he quckly bought a P3 and disconnected the factory unit in his 2012 Powerstroke.
You are the winner. Hope the other guy is tire wise
Looking for advice before your next adventure? Look no further.25,187 PostsLatest Activity: Mar 17, 2026
