monkey44's avatar
monkey44
Nomad II
Oct 02, 2019
BFG tire disintegration
[img][/img]
Tire issue - this disintegration happened on a back road. I noticed a low-air warning - looked at tire, seemed OK not flat, not even visibly low. Then drove about a mile or so, heading to the service station to air it. Then this, altho, had to drive about 100 feet or so on it as the road has runoff ditches on both sides - no place to safely pull off.
After removing tire, found a nail embedded, but should only be a slow air leak.
In case you can't tell BFG E 285 70 17 ... 32K miles, about seventy five percent with a 2800 lb Lance camper, not a lot of off road anymore, mainly highway. About 2.5 years on tires. Anyone know of any issues with the BFG KO-2???
Oppps, tried to post image - got that symbol instead - help with image??
  • If that nice truck spends much time hauling a camper, I’d look for some 18 or 20” takeoff wheels anyway so you can put some heavy duty tires under it.
    Good time to doo it when you need new tires. Can usually get a new or nearly new set of tires and wheels for the cost of just a high $ set of tires.
  • Not a bfg issue imo, but pretty light tires for camper duty being 17s
    Just an unfortunate flat imo.
  • After removing tire, found a nail embedded, but should only be a slow air leak.
    Tire with 32k miles under a truck camper... tire ran on low pressure to long....tire ran hot till it came a part which is to be expected of any tire under those circumstances.
  • Yup that happens sometimes. How old of tire? Lost one, not a bfg on my work truck a couple years ago. Screw in tire, went flat on freeway. Buy the time I could pull over it was cut similarly.
    Those aren’t very heavy duty tires for hauling that camper given they’re 17s. So there’s that. The back tires have been at max load anytime the camper was on the truck.
    IMO not a bfg specific issue, just an unfortunate flat.
  • wnjj's avatar
    wnjj
    Explorer II
    You had double IMG tags.
Looking for advice before your next adventure? Look no further.25,127 PostsLatest Activity: Apr 23, 2025
