lawnspecialties's avatar
Jul 13, 2015
Big Electrical Problems
Went to the lake this weekend. Since we are usually running off generator power at our races, camping at a campground is a treat. Nothing like plugging in and being able to run just about anything you want, when you want. Well, that idea got me into a pickle this weekend.
Saturday night after our showers, I smelled a burning electrical smell. Nothing overwhelming but obviously a concern. It slowly got less and less so I blew it off.
Sunday morning after the wife got her shower, she woke me up to say the electrical burning smell was back and stronger. I got up and sure enough, it was worse but again, nothing overwhelming and no smoke visible.
After I got to thinking about it, I deduced it had to be our electrical water heating element. When we are at our races and on generator power, heating water electrically pulls so much current, I just do it with gas. So our water heater hasn't been heated electrically in over ten months when we last camped at Willow Tree. I was sure it was just dust burning off or something so I pulled a panel to watch it. Turned on the switch and after about three minutes, the smell was coming and I could see little whiffs of smoke. So we shut it down to gas power only and opened all the vents to air the smell out.
Now go back two weeks ago to when we had the AC unit replaced under warranty. Our AC unit had a small freon leak and it was causing the unit to freeze up. Literally make ice chunks and one time last fall, it locked it up because the ice got so thick. When it did it that time, it melted the power cord connection slightly. So the dealer was happy to give me a new cord as well when the AC got replaced. It wasn't the exact same black cord but it was a 30A rated cord, just a different brand.
Now back to today when its time to go home. Started breaking everything down. All was fine and we had the new AC running nice and cool. After I got the truck hooked up, I pulled the water hose and the cord from the meter and went to unhook both from the camper. As I got near where the power cord plugs into the camper, I could smell the burning electrical again. I grabbed the plug at the camper and it was hot. Unscrewed it, pulled it out, and one of the legs was totally burnt up. A melted mess and slight smoke.
So now I have to take it back again. Obviously the cord is no good and the connection on the camper itself has to be replaced. Both are burned up pretty good.
Any ideas what this could be? What would cause a power cord to melt at the camper? Running the AC and heating water with electricity shouldn't be that bad. Its not like it was running for hours and hours on end. No breakers in the camper ever tripped nor did the breaker at the power box of the campground.
  • High amp draw, coming through a connection that is either corroded or slightly loose. The contacts, in the cord end, are spring loaded. As they wear, they get loose. Maybe, something (wind, a branch, etc) was making the cord move back and forth.
    Looks like it's time for a new power inlet and, at least a new end on the cord.
  • I'd suspect it was a loose contact on the cord. Only one side of the circuit burned, and the current needs two sides to complete the circuit. I'm not an electrician, but I'd suspect that cord.
Looking for advice before your next adventure? Look no further.25,149 PostsLatest Activity: Jul 17, 2025
