dcmac214's avatar
dcmac214
BIG Waste Water Tote Wanted
(Another internet search where I couldn't find what I think I want)
Where can I get a large capacity waste water tote?
The biggest I saw on the internet is 42 gallons, one gallon shy of my black water tank. I'd like to get one at least 60 gallons so I can dump my black and two grey water tanks in a single trip.
I originally thought I'd try making one with a 55g drum but the RV drain pipe is too low to make that practical.
  • I have a portable 25 gallon fresh water tank and there is no way I am moving that around when full.
  • 60x8= 480lb.
    My guess is that's going to be one beefy and expensive tote. Maybe you can build one yourself and mount it in your truck bed, because that's the only way you're going to be able to move it.
    I move mine on a hand truck.
  • 340 pounds=only tank he can find. You must be a youngster or dang tough.
  • After dragging my 25 gallon tote once by hand dump site was fairly close) I decided that wasn't going to happen again.
    After dragging it a an idle behind truck to dump station a couple of times I decided that wasn't going to happen again.
    From then on.....used a portable FloJet macerator pump when I could reach a clean out
    OR when tanks were full just hooked up 5vr and went to dump station. Either needed to fill fresh water tank again OR was headed out anyway.
    Totes.......no thanks. PITA to use, to haul, to dump, to stow. Not worth the hassle.
  • I manually used to use a 15 gallon on a TT. Motor home now, won't use one
    of them again ever!
    Brian
  • A full 42 gal tank ( LOADED) will be in the 350 LB range. You really do not one larger as the 60 gal tank would be in the 500 LB range.
  • I think 42 gal is the largest. Can't you use a 42 gallon and dump prior to being 100% full.
Looking for advice before your next adventure? Look no further.25,107 PostsLatest Activity: Jan 29, 2025
