old_guy's avatar
old_guy
black tank blocked
when in Yuma last winter I learned a lesson and boy I don't want to do that again. I went out to empty the back tank and pulled the handle. every thing was going fine until DW called me to tell me something and BANG a senior moment. I forgot the close the valve on the black tank. a week later I again went out to empty and the handle was in the out position. I knew I had screwed up. luckily I was at a lot in Yuma that had other facilities and I went to the RV dealer in Fortuna and got a bottle of black tank digestor. poured that in and waited a few days and put as much water in as I could and pulled the handle. clean as a whistle. lesson learned, do not leave the area until the black tank is empty and cleaned then close the valve. I still counting my blessings on that one.
  • Bobbo's avatar
    Bobbo
    Explorer III
    You are lucky you found it so quickly. A week isn't really enough time for "stuff" to petrify completely. Remember, even with the drain open, the tank is still a damp environment. If it had been 6 months later, you may not have been so lucky.
  • normally I do not use digestors in my black tank. the only reason I used it is the rv guy said it would cost me about $200 plus to have the people who do tanks to come out and clear the blockage. he said you only have $12 to loose if you try this stuff first. I usually empty the tank and hook up a quicky sprayer to clean the tank out and to clean the probes. I know for a fact I got lucky on this one.
  • And there are those that say digestors are a waste of time in the black tank.
    Maybe some of them will read this. Possibly those that repeatedly have clogged tanks.
Looking for advice before your next adventure? Look no further.25,184 PostsLatest Activity: Sep 04, 2018
