Nutinelse2do's avatar
Nutinelse2do
Black Tank Leak
Not a crack, just weeping when the tank gets almost full. Found the spot.... It's the tank its self, not a fitting. Again... not a crack, and not the fittings.
What do we use to repair it?... Tried ABS Glue, which did nothing. Read on Bondic, and Flex Seal, which both get pretty crappy reviews.
What would be the best option to fix it? Fiberglass welding, glass cloth and 3m sealant, plastic tank repair kit?
Please let us know if something has worked for you. We really don't want to replace the tank.
Thanks for your time
  • I have had good luck with Mighty Putty; but, I have never tried it on HDPE. I have also seen what I think is a similar product at ACO or ACE called epoxy putty or something like that. I would advise reading the label first and see if it works on HDPE.
