Dtaylor's avatar
Dtaylor
Black tank odor
The last several time we have camped, when we shower, we are getting a strong odor from the black tank. It seems to happen when the tank is about 1/2 full. I have tried various chemicals but they do not seem to help. The tanks are clean when we start. Normally, before leaving home I put about 5 gallons of water in the tank. I even tried adding Pine Sol this last trip but no help. Any idea what may be causing it??
  • Are you running an exhaust fan while you're in the shower? Is the toilet nearby with the lid open, perhaps?
  • It is not from grey tank. The odor is black tank. I poured a bunch of pine sol into black tank and that is the odor we got last time. I am not sure why it seems to happen when we are showering. We do run the vent fan when showering but not when toilet is in use. I am not getting any odor from grey tank
  • Showering and strong odor from black tank.......:H
    The 2 are not connected.
    Shower drains to grey tank.
    Could be 'stuff' in shower 'P' trap that is getting stirred up while using shower.
    Could be the air admittance valve under bathroom sink that is getting pulled open while shower water is draining down to grey tank (grey tank odors can stick as bad as black tank)
    Could be smelly Hot water while using shower........which would also smell when using any hot water.
    Just don't think smell is from black tank while using shower (unless someone is using toilet at same time)
  • Might check your vent stack or vent valve to make sure they are working properly.
    Hope this helps.
Looking for advice before your next adventure? Look no further.25,179 PostsLatest Activity: Jan 08, 2026
