dennislanier's avatar
dennislanier
Black tank problem
Currently at a campground in North Georgia mountains. This morning as I tried to empty the black tank I pulled the handle but the tank did not drain. I have come to the sad conclusion the the handle has pulled loose from the valve and therefore the valve is stuck in the closed position. My obvious question is can the tank be drained manually so I can replace the bad valve. Keep in my that I am in the campground. I just want to have some way to drain the tank now or else I will have to pack up and leave. It shows about 2/3 full now. I realize I can use the campground facilities but my main concern is draining the tank.
  • Wanted to add, if you can find a direct replacement valve, buy it or better yet, buy two. Bring it home and take it apart. Then you will understand exactly how it is sealed internally, and where you can cut to minimize unwanted leakage. I think we can agree that leakage, would be unwanted, yes? :)
  • I think I may replace mine "just in case" while its empty. Trailer is 10 years old and I sure don't want to deal with that.
  • bpounds wrote:
    Sounds like this guy had a similar issue: Clickable Link
    Thanks for this link. Looks like my problem exactly, and how to fix it as well. Guess I will get to try it out soon. If so I will follow up so it might help another poor soul.
  • I had the exact same thing happen to me a few weeks ago in a West Yellowstone RV park. I managed to stick the rod back in the hole, find the threaded end of the valve and screwed it back into the valve. I was amazed that I could stick that rod back in the hole and find the threaded end on the valve but I did and it's stayed in place since then.
Looking for advice before your next adventure? Look no further.25,102 PostsLatest Activity: Jan 18, 2025
