dennislanier's avatar
dennislanier
Black tank problem
Currently at a campground in North Georgia mountains. This morning as I tried to empty the black tank I pulled the handle but the tank did not drain. I have come to the sad conclusion the the handle has pulled loose from the valve and therefore the valve is stuck in the closed position. My obvious question is can the tank be drained manually so I can replace the bad valve. Keep in my that I am in the campground. I just want to have some way to drain the tank now or else I will have to pack up and leave. It shows about 2/3 full now. I realize I can use the campground facilities but my main concern is draining the tank.
Looking for advice before your next adventure? Look no further.25,125 PostsLatest Activity: Apr 16, 2025
