Travlingman's avatar
Travlingman
Explorer II
Dec 27, 2014
Black tank valve leaking
My black tank valve is leaking. Started out that it wouldn't close all the way, could tell where handle stopped when pushing in to close. Now the handle doesn't close by 1/4 inch, and tank is losing a lot of water. Has anyone found a chemical or something that would clean out the valve? We are living in camper now, so trying not to replace valve if I can come up with a way of fixing it until spring. Using a cutoff valve at end of line now so tank doesn't go dry.
  • You might have toilet paper stuck in the gate valve. Drain the tank then run a hose up inside and blast it.
Looking for advice before your next adventure? Look no further.25,183 PostsLatest Activity: Feb 21, 2026
