mich800
Jul 21, 2013Explorer
cm11599ps wrote:path1 wrote:What would he actually be gaining by using that cap?
Pretty had to get passed "termination" cap if valve is bad or opens when traveling.
Right, but then you still have the same problem with junk water right behind the cap. Same problem, just a different cap, right?
I agree. The only thing you gained is knowing will get dirty. I use the gate valve at the end with the cap with threaded hose end. If a tank valve fails or someone opens it I still have the fail safe to attach the sewer line if there is a problem.
Looking for advice before your next adventure? Look no further.25,199 PostsLatest Activity: Jun 10, 2026
