Jackfate's avatar
Jackfate
Blackstone griddle regulator adapt
Looking at said griddle. Wondered if someone had removed the regulator & plumbed to the external gas outlet . Like I’ve already done on a weber Q. Fittings on the blackstone are not like a Q.
  • I haven't, but it looks almost identical to my coleman regulator/fitting. I plan on ordering the same parts for the blackstone griddle as I did for my coleman. You just have to remove the regulator and install the quick disconnect.
  • I would be interested in knowing this too. I have the griddle and used it on our last trip. I have a propane "tree" that I use for the other grills but I had to hook the griddle directly to the 20 lb tank due to the coupling.
Looking for advice before your next adventure? Look no further.25,179 PostsLatest Activity: Jan 16, 2026
