WyoTraveler
Sep 12, 2014Explorer
If done correctly either way works well.
Blowing out the lines just seems to be easier and quicker for me. I can blow out the lines and winterize in about 15 to 20 minutes. Could do it much quicker before I had a W/D. I have a portable commpressor and I can winterize and de-winterize on the road.
The advantage of blowing out the lines is you don't have that yucky stuff in your water lines. Every spring check out the posts about water still tastes funny after flushing RVantifreeze out.
I use a regulator on my compressor To keep pressure below 45 pounds. Plus I always have one water valve open all the time during the process. Open 2nd valve then close the 1st valve.
W/D: I disconnect the water lines from the washer and blow out those valves/lines the same way. I pour about 1/2 gallon of antifreeze in my Washer and turn it on and spin it out. That antifreeze will fill the washer drain trap
I pour antifreeze in all the drains. Make sure it is enough so some goes down into the grey tank and keeps the grey dump valve moist.
Don't forget to open toilet flush valve so that also gets blown out & also outside shower valve if you have one. I also add some antifreeze to black tank to keep black tank dump valve moist. Then add some to toilet bowl. BTW if you have any water filters remove the housing water will collect in the bottom of the filter housing.
Works for me. We get chilly in NW WY and no problem with blowing out lines. Down to 20F this morning. We will get down to 25 to 30 below in the winter.
Looking for advice before your next adventure? Look no further.25,211 PostsLatest Activity: Sep 01, 2026
