jfkmk
Sep 12, 2014Explorer II
Either away works well as long as it's done properly. I use blow the lines as I'm doing other winterizing chores then add the antifreeze. If you set up the bypass valves correctly, don't get any antifreeze into your water heater or fresh water tank, then do a quick flush when dewinterizing, you won't get the funny taste.
Looking for advice before your next adventure? Look no further.25,211 PostsLatest Activity: Sep 01, 2026
