WyoTraveler
Sep 12, 2014Explorer
Dr Quick wrote:
I would not recommend that you blow out lines unless you have a clean source of compressed air. Air compressors have oil and rusty water in the tank, and it will get into your lines.
Are you referring to your air compressor? Most people I know drain moisture from their air compressors on a regular basis. If you let moisture build in your air compressor you risk rust and blowing a tank due to rust.
Looking for advice before your next adventure? Look no further.25,211 PostsLatest Activity: Sep 01, 2026
