- gmw_photosExplorerI chose Blue Ox over three years ago, and am happy with how it works.
- TurnThePageExplorerI've had my EQ for over 10 years and have been very satisfied with it. I've never experienced that bumpy ride thing. In fact, when it's hooked up, my truck handles much more stable and firmly than non-towing. It does get a little messy and can be noisy. That new Blue Ox Sway Pro is looking pretty good too. If I buy another bumper pull trailer, I will seriously consider switching.
- 3oaksExplorer
Steeljag wrote:
Five years with the Equal-I-zer brand hitch with no issues. Like it, and would buy another!
Same with me. Nine years using an Equal-i-zer hitch. I'm very satisfied with it. No compelling reason to change. - Community AlumniI tow with a 12K Equali-z-er and it has been great; no real sway and my rig is level. It's simple to hitch, unhitched and I can back up without disconnecting anything.
- fla-gypsyExplorerReese Dual Cam
- SteeljagExplorerFive years with the Equal-I-zer brand hitch with no issues. Like it, and would buy another!
- gclossExplorerI had a Reese Dual Cam on my last TT and now a Blue Ox. Blue Ox is very quiet, almost grease free, easy to hitch-up and and Made in USA.
The Reese Dual Cam did a great job, but I like the Blue Ox better. - goducks10ExplorerWith that truck I'd go Andersen. You won't need to transfer hardly any weight back to the front. The Andersen has a hard time transferring heavy TW with 1/2 ton trucks. Not your case. I used one for a short period of time before we got our 5th wheel. I had a 31' TT @7300lbs. I used a 12 Ram 2500 CTD. It did everything as advertised. Smoother ride and no sway. I had previously used an EQ and was looking to get away from the bouncy ride, noise and grease.
- jerem0621Explorer III'm going with the Andersen.
While it may not get you back to 100% restored front axle weight it will get you back within WD recommended specs on front end rise.
Anderson's approach seems to embrace the "Looks level to me" philosophy. As long as the handling is good on the end and the Rig looks relatively level then the Andersen is doing its job.
The real beauty with the Andersen is its weight and ability to control bounce. I would recommend calling Andersen and ask them directly, they told me straight up that it's not as good at dialing in WD as a spring bar hitch, but really shines for it its other performance characteristics.
thanks!
Jeremiah - I love my Blue Ox. Works great.
Looking for advice before your next adventure? Look no further.25,136 PostsLatest Activity: May 29, 2025
