JBarca
Feb 18, 2014Nomad II
Highway 4x4 wrote:
So looking at the Blue Ox sway pro unit and wondering if there is really any anti sway control in that hitch using the WD bars as the anti sway device? Does anyone have one and feels there is good anti sway control with it? Towing a 30ft, 7K pound TT with a Dodge 2500 diesel.
Hi,
There have been several iterations of the Sway Pro over the years. If you are buying new, and the dealer has the most recent, the hitch head is a non-adjustable head. The head was made this way on purpose by Blue Ox.
Here are 2 threads where it was discussed in more detail on the new fixed tilted hitch head version and attempts on how this hitch actually works for anti-sway. I do not know if there has been a definitive answer as to why it works. I may have missed that post. Especially when the instruction manual of the time stating that if excessive sway is noticed, to add more tongue weight as a fix. H’mm, OK. I myself have not come to grips with the castering effect they use as an effective anti-sway. However Sway Pro declares it works, just they do not go into enough detail to figure out how.
Good and Bad about Blue Ox Sway Pro
Eating Crow - the "new" Blue Ox Sway Pro
Folks who have used the Sway Pro have reported favorable replies, however they may not know or why it works, just their experience was good. There may not be a lot of sound data to compare the Sway Pro to say the Reese DC or the Equal-I-zer. Where either of those 2 hitches had bad results and then the Sway Pro fixed it. And if there was, I myself would question a few things on how the Sway Pro fixed it.
You have a good truck with good suspension matched to your size camper. Keep the camper loaded to keep the TW in the ~ 13 to 15% range per GVW and with good WD, the trailer should track well. The Sway Pro does WD well, although it does not have as fine an adjustment between WD settings like the older Sway Pro did.
As far as anti-sway, that remains a good question. The hitch does have many other nice features. Hopefully some day we may be able to get good data on “why” it works. With your truck and camper, odds are favorable from the responses on RV net you may have a good experience too.
Hope this helps
John
Looking for advice before your next adventure? Look no further.25,185 PostsLatest Activity: Mar 05, 2026
