coolbreeze01
Feb 19, 2014Explorer
Highway 4x4 wrote:
OK, it works, somehow, it's the caster. I am kind of old school, I can see how the friction ones work. So, the more you turn the more force there is to put it back straight. So what about tight turns in a CG or gas station? Also I am going to need a 2 1/2 inch shank for the class 5 hitch. I will need a crane to lift it. I know a proper loaded TT and hitch doesn't sway. But what about that cross wind and then a semi goes by on the wind side, there is the sway.
You can't control the wind or semi's. You can control your own speed.
Looking for advice before your next adventure? Look no further.25,185 PostsLatest Activity: Mar 04, 2026
