Heap64
Aug 06, 2014Explorer
I installed one on my camper last year in the dealers parking lot in about 30 minutes. They have to be one of the easiest hitches to install as there is no angle to have to mess with on the head when installing.
The main thing is you want your camper level or a little nose down. For sure not nose high while towing.
Take measurements from the ground to the top of your wheel-wells before hooking up to your trailer. Of course your rear will drop some with load. You just don't want your front of your truck to raise up.
You can add more weight distribution by reducing the number of chain links on your latch up to help bring the front down if needed.
I would suggest getting a socket and a nice breaker bar to carry with you to latch up the chains and forget the short tool they give you.
Hopefully I helped some.
Looking for advice before your next adventure? Look no further.25,203 PostsLatest Activity: Aug 03, 2026
