Robin1953
Aug 07, 2014Explorer
I believe that when it says to make sure the vehicle is level means that the drop when the trailer is attached should be about the same all around. When I installed a Reese hitch one time I measured the height from the ground to the rear and front bumpers before and again after. The difference in drop front and rear was less than a quarter of an inch so I called it good and it work as it was supposed to. As someone else stated you just don't want the headlights pointing to the sky.
Looking for advice before your next adventure? Look no further.25,203 PostsLatest Activity: Aug 03, 2026
