carringb
May 22, 2018Explorer
I run 9 links. My tongue weight us usually 1500-1800 pounds with 1500# bars. I rarely have to extend the jack fully, unless I'm in a dip. I'm not sure I could run 10 links, and seems like that could cause binding on a tight turn where the trailer is almost 90 degrees from the rig.
I don't think full front axle weight restoration is needed (or even desirable) on an already nose-heavy diesel.
Also, 9 links allows for the half twist in the chains, which prevent binding. I tried 8 links initially, and the straight chain would just barely catch the head of the pivot pin, and wedge itself in there.
Looking for advice before your next adventure? Look no further.25,206 PostsLatest Activity: Aug 22, 2026
