TenOC's avatar
TenOC
Nomad
Aug 15, 2015
Borax Ant Killer.-- Cheap and Effective
For a number of years I have been using Terro Ant Killer to control the ants around and inside my RV. I think it does a very good job, but it is somewhat expensive $5.00 (?) for a 1 oz bottle. The other day I read the ingredients on the small bottle and much to my surprise I found that Borax was the active ingredient. When in FL I use Borax as a very effective control of roaches. One can purchase a very large box of Borax for about $10.00 in the laundry area of most stores Amazon 20 Mule Team Borax. So I decide to make my own ant killer.
The recipe for homemade ant killer is three parts sugar to one part borax. This means that one cup of sugar can be used with 1/3 cup of borax. Mix these ingredients in a bowl to be sure all lumps are crushed and loosened. Add enough tap water to make the mixture thick and pasty, without being runny. Around 1/4 to 1/2 cup of water should be sufficient to attain this consistency. Using a fork or whisk, stir the water into the mix and then add approximately 1/4 cup of syrup to the mix to make it sticky. As added flavor, I add some bacon drippings. This should create a thick goo which will be irresistible to any household ant.
This will give you enough ant killer to last a year or so. Spread the ant killer around the outside of your RV. Inside the RV, I place some on paper towels or cotton balls.
Looking for advice before your next adventure? Look no further.25,129 PostsLatest Activity: Apr 26, 2025
