rhagfo
Jul 21, 2013Explorer III
exeter_acres wrote:Atlee wrote:
What is unsafe about having both cylinders open at the same time?RamTX wrote:
Just for safety purposes, I use one tank at a time, i.e. keep the cylinder valve closed on the tank not in use.
my question as well
I will third that question and add that i leave my propane tanks open 24/7/365.
I believe that this system should be as tight as a house gas system, so should be able to be charged all the time. We also try to get out at least once a month year round. If it is going to leak what better way to find out? I have a battery disconnect so no ignition source while store. I open door smell then activate the disconnect.
Looking for advice before your next adventure? Look no further.25,199 PostsLatest Activity: Jun 10, 2026
