colliehauler
May 30, 2015Explorer III
redhooker wrote:They are correct on it being a big job. You need to remove the slide to do it right. On my Wildwood part of the floor under the slide needs replaced as well. It will run me about $3500 and I'm supplying the new carpet and paneling and trim. There is only one place I know to get the 12' long plywood for the floor is in Indiana.
Wood is soft along side wall about 6 inches entire depth (3 feet apron) and loose from side wall. Bottom plate of wall soft about 50%. They quote for just those 2 items repaired 26 hours of labor at $119 per hour and $600 materials.
That does not include carpet, trim, or wall paneling which all also need to be replaced-carpet is black moldy; trim rotted; paneling rotted 1 foot up wall and has already been cut out
Looking for advice before your next adventure? Look no further.25,204 PostsLatest Activity: Aug 13, 2026
