John_Wayne
May 24, 2015Explorer II
And after you get the chain lenght hook up the toad with just the chains or cables pull the toad back till the chains or cables are tight and make your break a way cable 4 to 5 inches shorter. So the break a way pin is pulled before the chains reach max lenght.
Then if the toad breaks away it's not running into the back of the MH as you pull to the side of the road.
Looking for advice before your next adventure? Look no further.25,199 PostsLatest Activity: Jun 08, 2026
