willald
Jul 21, 2017Explorer II
Nutinelse2do wrote:
mowermech, We will just continue to use our RVI 3 braking system, with a breakaway cable, and be legal everywhere.
In towing, It doesn't matter what State you are from, like a drivers license for a vehicle over 26k, it depends what State you are in at the time.
Here's the Brake Buddy tow guide, that specially states, if " what you are towing " is at or over the listed weightsBrake Buddy tow guide
To each his own. It's a safety issue. It's already dangerous enough out there driving these rigs around. Why chance it?
Happy camping and safe travels
...As mowermech pointed out, you have to be careful when you quote 'towing laws' posted on the websites of brake system manufacturers. Its a little like asking a drug dealer if what they sell is addictive or not. The 'advice' given there is going to be just a little skewed, and not very reliable. :)
If you feel better using a brake system, by all means, use it and enjoy. They probably are a good idea in most cases. We use a ReadyBrake system (ReadyBrute tow bar), and are very happy with it.
However, don't be misled into thinking that such systems are required by law in 'most states', because it just isn't true. As mowermech pointed out so well, when you really look close at the REAL laws (not brake system manufacturer's lose interpretation of such), you're going to find that the majority of states do NOT require such. And, in the states that they are required, the laws are frequently sooo vague, they are just about impossible to enforce, anyway.
If you do get a system, I recommend systems that are not a 'brake in a box' type setup that you have to put in and take out each time you tow. Problem with those is, having to constantly install and set it up, you introduce a lot of extra risk there for not doing something right one time, and potentially causing bigger problems than not having a system at all. That, and there is the temptation, that for shorter trips, you may decide not to put it in at all. And, Murphy's law is that such a trip would be the one where you'd wish you had put it in!
Better to have a system that stays installed, and all you have to do is plug it in or hook it up and go. That way its always installed and working when you tow. Systems of that nature include Air Force One, M&G, Readybrake, Invisibrake, etc.
Looking for advice before your next adventure? Look no further.25,210 PostsLatest Activity: Aug 29, 2026
