enblethen wrote:
If you decide to rewire the brake circuit, get proper brake wire. It is two conductor sheathed cable. The sheath protects the conductors from the chaffing.
"SJ" type wire can be used
HEREwhich is a heavy duty flexible jacketed cable.
Or do like I did, use flexible plastic conduit and regular stranded building wire (I have "leftovers" from home wiring projects so that is what I used). "SJ" cord, flexible plastic conduit and stranded building wire ALL can be easily found at Home Depot or Lowes.
Using SJ type cord or plastic conduit I do not think that it is necessary to buy "brake wire"..
