joelcop's avatar
joelcop
brake controller installation
I am installing a brake controller on a 2014 Ford Flex. I haven't been able to locate the stop light wire under the dash. If anyone has any information on locating the wire it would be greatly appreciated.
  • Engine oil cooler or ATF cooler or both? Highly recommend more than just a "short ATF tube inside the radiator" level of ATF cooling.
    Custom wiring a brake controller isn't that big a deal. I like to find where the TV harness plugs into the brake pedal switch itself and add another wire there rather than relying on a snap lock type device. But to each his own. There is certainly nothing mystical about a ready-made plug that makes a vehicle more "tow-worthy" than a similar vehicle that lacks it.
  • I am just looking for the brake light wire. I have already connected the other wires for the controller and the 7 pin trailer connector. Still need to add the oil cooler and I have the equivalent of the factory tow package.
  • bikendan wrote:
    joelcop wrote:
    I don't have a factory tow package.
    I can't find the wire at the brake pedal.
    I'll have to take another look.
    if you don't have the factory tow package, it doesn't have the wiring for a brake controller.
    i'm not aware of the controller working with just the stop light wire.
    how will you deal with the 7-pin trailer connector?
    no way would i use a Flex without the factory tow package, to tow anything, especially something that requires a brake controller.
    I think he's just looking for the brake light wire. But I would agree with what you are saying.
  • I don't have a factory tow package.
Looking for advice before your next adventure? Look no further.25,180 PostsLatest Activity: Jan 21, 2026
