waynefi
Oct 13, 2018Explorer
Brake emergency (breakaway) cable problem
I had an interesting experience with a trailer emergency brake cable, the one that activates the brake if the trailer breaks loose from the TV. I came back to the trailer, and saw the switch end of the cable sitting on the ground. My first thought was that I had been towing with the brake on, and burned out my brakes. But I tried reconnecting it and activating the brake with the controller knob, and everything seemed OK. I tried moving the vehicle with the switch pulled, and it was immediately obvious, very jerky, so no way was I driving with it out.
I have no idea what made it come out. I wasn't doing any rough roads or hard turns just before that. I have towed this rig for close to 30000 miles and never had a problem before.
I'm not sure what the best way to connect the cable to the TV is. The cable is a bit long. If I just hook the cable to the truck near the hitch, the cable is long enough that it almost rubs the ground, so I snake the cable across the hitch to take up the slack. I think that getting the right length is tricky. If the trailer ever came off the hitch, and was being dragged by the safety chains, I would want the brake to be applied, right? The full length of the cable is long enough it probably wouldn't get pulled. But if I take up too much slack, it could get pulled accidentally. I'm not sure what the perfect length is.
