travelnman's avatar
travelnman
Break Away Cable
Anyone have an opinion as to where to hook the break away wire. The
folks I bought the TT from had it clipped to a link on the safety
chains. I thought it should be attached to the tow vehicle but who
is right. If the TT comes off the head then the chains are the
only thing holding it and that wouldn't last long before they
break or snap off taking the break away wire with it. If it was
hooked to the tow vehicle I would think that the cable would be
pulled and activate the trailer brakes. RV dealers have all different
opinions on this and if questioned treat it like "it don't matter
where you put it". I had the nut on the ball come loose and fall
off, it had a lock washer and I checked often. I got home only
because the shaft was long and jammed into the hitch. You say
how did this happen. Wisconsin interstates especially around Madison
caused the whole rig to "pogo" bounce or porpoise. Others have
experienced this and told me it is because of the expansion joints in their highways.
We don't get this anywhere else in the country.
Now you understand why I'm concerned about the brake away cable.
  • Safest is a separate from the hitch, just in case the hitch receiver fails, the brakes come on. Also, the cord should be long enough, so if there is a ball or drawbar failure, the pin will pull out before the chains get tight, that way the brakes come on if the cord pulls out when it happens.
  • when we had a travel trailer we used a carabiner on the cable and hooked it to the same place the chains go on the hitch.
  • If you have a commercial rig and you stop at the scales, the DOT guy does not like it that way. We had a few DOT inspections where I used to work and that was pointed out to the driver. Hooked to the tow vehicle not the hitch
  • dodge guy wrote:
    I have mine attached seperate from the safety chains. The chains go to the hitch and the breakaway cable goes to the bumper.
    X2
  • I have mine attached seperate from the safety chains. The chains go to the hitch and the breakaway cable goes to the bumper.
Looking for advice before your next adventure? Look no further.25,162 PostsLatest Activity: Sep 02, 2025
